Hi there, im about to pick up a 01 Bullitt mustang with 60k on it. I am completely new to these cars and was wondering if there is any scheduled maintenance that should be done around this time? Also what do you guys suggest i do and get checked out?
I would suggest air and fuel filters and a manual tranny fluid change. If unsure when the coolant was changed, get that too. I assume it has a fresh oil and oil filter, if unsure change those as well. Also check the rear end fluid, brake rotors and pads and tire wear.
