Power loss?
Old 05-06-2009, 07:28 PM
  #31
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
Originally Posted by Hangwire
Heh ok bud.....heres the best way to put it. In order to have any stability in a vehicle that has to put more power to the ground than whats really needed to move it(pulling heavy things, racing, etc) you need that power to go to both wheels. Thats simple physics. In most daily driver cars...for example a honda civic...the power is only being put to one tire. You're not pulling anything and if you're intelligent you're not racing with a civic.
For example.....have you ever been to the lake and seen that one dumbass that cant seem to pull his boat out of the water and hes wondering why? Its because hes doesn't have limited slip so his power is only going to one tire and hes spinning the **** out of that on the wet slope. All of his power is going to his right or left tire, yet theres alot of weight on connected to the opposite side of his truck. In effect the left side of the boat is essentially receiving 0 pulling energy from the truck so he goes nowhere.
Instead of about 250 HP going to both tires for you, its now 250 HP going to only one tire. Its only ocassionally locking out because its worn down bad. You need to re-build your
T LOCK. Its as simple as that.
Unless your a very experienced driver and you know how to get that one tire to hook it will significantly effect your 60 FT times. Get tha **** fixed!
could be but it also could be as simple as when he did the 1 wheel peel the ground have been at an incline or something...it may not be broken if it was an isolated incident
99BlackPonyGT is offline
Old 05-06-2009, 08:17 PM
  #32
agarr19
agarr19's Avatar
agarr19 is offline
Old 05-06-2009, 08:42 PM
  #33
99BlackPonyGT
wow OP youre a tool....
Old 05-06-2009, 08:43 PM
  #34
agarr19
agarr19's Avatar
..goddamit why do i always get ripped on
agarr19 is offline
baddog671
07-26-2016 01:20 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Power loss?
