Ok I Fixed One Thing An Another Goes Wrong, HELP!
Ok first i have to tell you one thing that may be causeing this before the actual question lol. My car's airbags arnt set up, i have to get new sensors and i have the air bag blue box thing that has to be set up by ford or something like that, so i think that has something to do with the problem. but anyway the other day, i had replaced my Odometer/trip meter gear in my car, and of course while doing this they tell you to diconnect my battery. So i did and replaced everything and when i started it back up it now beeps, it will beep in intervals of three about fifteen times. And there is a little blue box right behind the CD player (Which i think has to do with the airbags) that i think the noise is comming from. And the airbag light isn't on anymore (It was before i did all this) i hope someone can help me with this messed up stuff lol.
Thats the "Diagnostic Monitor" telling you its fubar'd... Its not that bad to replace... Its behind the radio and HVAC controls. Once you replace it, the only thing it says to do is "prove out" the system
Prove Out System
PROVE OUT SYSTEM means to turn the ignition switch from OFF to RUN and visually monitor the air bag indicator with the air bags installed . The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag system fault is present, the air bag indicator will either:
Prove Out System
- fail to light.
- remain lit continuously.
- flash.
zanemoseley
09-06-2015 12:58 PM
