look what i got : )
look what i got : )
v-1 s trim, supposably only has 5k on it. they guy told me he threw a belt on it once. once we made the deal and such i was home looking over everything and drooling and i noticed there was some of the belt wrapped around the input shaft of the pulley. one of the strands got between the shaft and the seal. so i pulled the pulley off, and usually on seals you can actually see the rubber of the seal on the very outside edge. i dont see any part of it what i think the seal would be. and on the shaft there is very little oil, so it may not even be leaking.
from what i found searching google, its possible for me to replace the seal myself, has anyone done it?
any now for a couple questions.....
does it look like everything is there?
is a 8lb pulley & the power pipe to much for a stock block?(he said he was making 10psi)
how the eff does all this go together lmao
