Plan of action?
You will end up spending more money in the long run though..
Alright after some research thanks for everyone who helped me with the rear end but its stupid to upgrade to the spline 31 cause ill never push that much power plus that money could be used else where so could you guys tell me if my plan is any good?
start with
Trak lok rebuild kit
gears
shortly after
adjustable shocks/struts
drag launch springs
rims and tires
UCA/LCA
Drag radials
then ill move onto the motor,
cai
pi swap
exhaust
headers
cams/with the pi swap
pulleys
then supercharger
dyno tune when all installed
Ive already priced it and for all this im looking at 5 grand and Im saving is this the right way?
start with
gears
shortly after
drag launch springs
rims and tires
UCA/LCA
Drag radials
cai
pi swap
exhaust
headers
pulleys
then supercharger
I would do gears first, exhaust second, PI swap third, everything else will fall into place.
Yehh, not a new sc sorry for the miss understanding i frankly see it as a waste to spend 5-10k on something that you could get for 1-3k Haha I have a poor mans budget but a richmans need for speed
you can definitely find good used blowers out there. i got my Vortech kit with aftercooler for $3k, all i needed were the fuel injectors and fuel pump (got used injectors on ebay and had them cleaned up, fuel pump from Haney Motorsport for about $100). it was a hell of a bargain cause that kit sells for probably close to $6k new.
there's a new roots-type (or is it twin screw? can't remember) from a company called Tork Tek or something like that. not sure if it's a quality blower, i know some magazine did an install and got good results but i've heard they're cheaply built.
