4k to spend...
4k to spend...
So by the end of the summer I will be running into a little bit of extra cash, around 4k or so. I was looking into supercharging my car but I wasn't sure which way to go. I've seen some vortechs out there as well as a kenne bell non intercooled for around that price. What would you guys do? Other options are welcome as well.
Thanks guys
Thanks guys
Maybe some of the blower guys will chime in, but from what i hear if you are going non intercooled you might want to stay away from a positive (kenne bell) displacement blower.
I have friends with non intercooled vortechs that don't have bad heat soak issues.
https://mustangforums.com/forum/4-6-...-kb-2-1-a.html
seems like we are dealing with the same question! My advice, make sure you have a solid suspension setup to handle and put down all that power before you spend spend spend.
put that 4k into a 5800 dollar Kenne Bell supercharger with big tube kit, and you will have the time of your life with your car. I was like you had 4k to spend and wanted to get something around that price, looked and read a lot of post and went with kenne bell. Install was so easy, they give you a tune for car which works great. Sign up for new credit card get 1 year no interest and pay 300 dollars a month
is 4K ur limit to spend? if thats so, u could probably get a Non IC supecharger setup from somewhere and run 6psi, which would give u 310-330 hp depending on your mods.
i would reccomend getting some of the basic bolt ons before supercharging, an upper plenum, catback, and headers if u can. thats going to let your car breath, so when u do supercharge it, you'll make more power.
if you want to stay in the around 300-310 hp range, for chaper you could go for ported heads, cams, and gears, and thatll run u $2-2.5K (with bolt ons)
If u wanna run around 390-400 hp. your going to have to spend $5K+ on an intercooled kit running around 9psi (with bolt ons).
it all comes down to how much money you want to spend, and what your goal for power is.
I'm gonna venture away from the S/C route.
Get a full exhaust, tb/plenum, a good set of custom ground cam's, the new Trick Flow heads, and a 100 shot of the crack. That should put you around 400HP on the spray and around 300 N/A. That will be cheaper than a *brand new* S/C set up so you will have some money left for suspension or visual mods.
If your dead set on the S/C then check out the $1500 S/C thread, it will take some time to find a good used head unit and you will have to piece things together, but would be well worth it for the money saved.
http://www.jmschip.com/shop/index.php?cPath=1_2 a few kits for under 4k , also check out MPH mongoose kits and Lethal performance has some kits too.
After reading several posts about each type of supercharger I'm leaning towards the kenne bell 2.1 non intercooled system. It's under 4k and comes with everything I would need, plus the install seems much easier than a centri. My question now is how does the non intercooled version perform? obviously I would only run 6psi but even with that would I be ok? I do live in Florida so it's hot as hell all year round...
