Anyone else have to replace headlight bulbs a lot?
I'm using the stock headlight assembly, everything looks normal. I haven't found any shorts in the wiring or anything like that. But I seem to be going through quite a few bulbs. It's the 9007 bulb, and I go through about 1 bulb a month. It alternates on which light goes out. Sometimes it's the driver side, sometimes the passenger side.
Anyone else going through these quite a bit? Or what should I do to troubleshoot my problem?
No, they're just regular bulbs basically. I had been buying the Sylvania Cool Blue 9007 Bulbs, but I changed it up and went with Philips this time.
That was my initial speculation (that or a short in the wires). I haven't noticed any moisture inside of the assembly... however, next time it rains I'm gonna double check.
All of my electrical accessories have been working fine with no problems. I know how to use a volt meter, I just don't know where to check... never had this problem before.
Afterall, I am buying them at AutoZone lol.
Well, I went through and tested all of my connectors and wires with a Muse (expensive little device I use at work). Everything checked good. So I unplugged all the connectors and plugged them back in just to make sure everything has good contact. This wouldn't be so bad if light bulbs were cheaper... but at $30 a set, it gets kinda old.
