is it possible?
is it possible?
stock auto 2003 mach 1 what will it run on the 1/4?
and what will it do with these mods? (hp and 1/4 time wise)
Removing the back seat, spare tire/jack, front and rear sway bars, and stereo amps
K&N drop in filter
Steeda ud pullies
ford racing a/c delete
bassing o/r x pipe
pypes 409 wiolator catback
8.8in housing/moser 31 spline axles
ford racing 8.8 limited slip diff
diablosport tuned 93 octane and 4.10 gears
with maybe some 26x10 slicks
K&N drop in filter
Steeda ud pullies
bassing o/r x pipe
I'd say about the same thing, with a great driver probably mid-low 12's at best. If they went with 4.30's they might be able to pull off a high eleven if they drive the **** out of it (seen it happen, that's the only reason I say)
depends on how far you plan to go with the car. If you plan on big power down the road (anything to trap more than about 110-115) you'll need significantly less gear, say 3.55's or 3.73's
Otherwise, I can't see a reason why it would be tough on the street (anymore than 4.10s), I know a couple people that drive their machs every day with 4.30's
im hoping that with a 3500 stall and a shiftkit along with an aluminum driveshaft the car should deep in the 12's maybe high 11's and since it's an auto i dont think the driver mod really applies to it as much. anyways this is something im hoping to do soon when i pick up a mach 1
