P1131 after longtube install
Well, I can't seem to get rid of this code. I check to make sure everything was connected right and it doesn't appear that I have an exhaust leak. I also got a mail order tune from Bama but I'm not sure it has to do with the tune. Anybody have any thoughts? It only started after I had them installed.
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
P1131 is Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
If everything is installed well without exhaust leaks I think it is a problem in the tune because of the better flow you have now.
get that code all the time. only thing the car will do is run a little more rich but the fix it to either turn off the rear o2 sensor or get that wire connector piece thing to cancel the code out.
09-10-2015 08:39 PM
