Starter heat soak?
Starter heat soak?
I never have any issues starting my car if it is completely cooled off. If I run in the store or something and right back out it's fine also. However if I warm it all the way up and try to start it like an hour later ( after a possible heat soak?) it is very slow to start. Is there a TSB or anything for this? What are some easy things to check? It's more embarrassing than it is anything. Sounds like I don't take care of it or something when it happens. I should note I only have 54k on the clock and live in Alaska and it was about 50 deg F outside this morning when it happened. Thanks!
logan409
09-26-2015 07:43 PM
