looking for help to make my car more for drag
#21
Ok...4cyl springs help a good bit, I have them. And my strange struts on my foxbody were quiet.
I run 90/10s 50/50s, 4cyl springs, and big n littles, with no front sway bar daily w no issues. Yes I just pit it in a guard rail, but that's because of the dragradials, not the suspension.
And keep the quads on
#22
ok that sounds great for me ima get 4cyl springs cut em and stock gt springs cut em and no front sway bar along with the 90/10s and 50/50s and sell my steeda tubular sway bar and the h&r springs and the bilstein ****
#23
I personally would leave the rear stuff alone. Like I said, I like the rear setup to be stiff and the front loose. I have FRPP C springs in the back (lowering springs) amd I get great weight transfer. If you find you don't like the rears like that, then I would swap.
IMO a stiff spring in the back helps to prevent the car from squating. Look at the pic of my launch, that is with lowering springs out back.
#28
assuming you are keeping the car lowered, look in to some foxbody struts
http://www.summitracing.com/parts/LAK-40511/
http://www.summitracing.com/parts/LA...NG&prefilter=1
#29
im gonna get fox 4 cyl springs for the front and cut em and keep the h&r springs for the rear
and y do the struts say for 2002? and the shock says 1993 does it not matter or something?
#30
Yeah I would like to know as well. I have plans to buy strange 10way adjustables all around with 4 cyl fox springs in front and whatever at the back. I've been hearing that I should use fox shocks/struts instead...
Can someone explain why and would there be any downsides? what woul the minimum drop have to be to be able to use them well?
Thanks
Thanks
