weight reduction vs adding horsepower
#21
i've dropped about 100 lbs from my car. i don't know if it's any faster but it definitely feels a lot more composed in the corners. annddd i get better fuel economy now (if any of u actually care about that lol)
so in other words...
more hp = faster in a straight line
less weight = faster in a straight line, better handling, better fuel economy
#22
Every Car is DIfferent, Different Power Bands and stuff. There is probably no Definite Number..
#23
There is no definite number. And there is alot of variables to look at, to reach a conclusion of a number. But what most people go by is by losing a hundred pounds it will shave about a tenth off your quarter mile time.
#26
+1 too many variable but typically its 100 Ibs equals .10 or so in the 1/4 for a typical car. could be more for a 13-14 sec car and could be less for a 10 sec car.
#27
I dont know about you guys but I can definately feel a differance when I remove weight.
I can feel a differance when my 180 lb friend is sitting in the car vs when he is not.
I cant also feel a differance when I take my rear seat out and my sound system out of the trunk.
In general I would say if you take 100 lbs off a 3300 lb mustang with near stock power you will see a .1 drop in ET.
but if you were to take say 300 lbs off that car I believe you could see more than .3....maybe because with less weight the car gets out of the hole a lot better but I would be willing to bet if you took a 250 rwhp mustang @ 3300 lbs, removed 300 lbs, that same car with a 3000 lb curb weight would run more than .3 faster given it has the tires to hold the ground
