need something to do to my car this weekend... ideas?
single adjustable struts allow you to adjust the extension (upward movement) and it has a preset un-adjustable compression (downward movement)
double adjustable allow you to adjust both extension and compression which is more suitable for the street but more expensive.
The right way to do it is to get the balljoints and a bumpsteer kit, not offset rack bushings. If you want to get stiffer rack bushings you should get standard offset poly ones or solid ones.
Offset rack bushings can make bumpsteer worse according to MM.
http://www.maximummotorsports.com/in...hing_tech.php?
i think a black Mach 1 with the FR's like your GT had and Slammed would look sick, but i think you saidyou want mineral gray.
sorry to hijack this 49er lol ( i can help you put some of whatever you buy on if you want)
i like the mineral grey, or white. i mean really all the mach 1s are sick to begin with
I like all the colors except the yellow ones. If I had my choice it would be DSG, azure blue or black but we'll see. You can expect to see a thread about it when I do pick one up, but it may be a couple weeks or even months. I'm really really picky about the condition and quite a perfectionist so it will take the right one to come along before I bite. I'll still be around spreading my limited knowledge and sharing my opinions between now and then though
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
