Uppers and Lowers...again
So I've got an extra 200-240 bucks to spend on some uppers and lowers. I've narrowed it down to these 3, which ones would you guys go with?
Any other brands or types are welcome as long as they fit the description above. Thanks ahead of time
http://summitracing.com/parts/SUM-790000R-W/
http://www.uprproducts.com/shopping/shopexd.asp?id=2117
http://www.stage3motorsports.com/pro...l_Arm_Kit.html
^+1, urethane us the cheapest possible way of making the bushings, and they will pound themselves to death in short order...
One thing to keep in mind is that if you buy "the cheapest there is", there is a good chance you will get "the cheapest there is"--it's not always true, however it happens more often than not...
I would run nor recommend ANY of the above linked LCA's/UCA's
What are the goals for your ride? DD with general upgrades? 1/4 mile and launching? Improvement on the twisties?
If this is the latter, steer completely clear of those arms and go poly/spherical. Those, as well as ANY good aftermarket arms, WILL introduce additional NVH into your ride, but those are WORSE than stock in some ways.
If you are ONLY interested in the 1/4 mile, a solid poly/poly will be OK.
Jazzer
Jazzer
No cheap parts ever!!! you will always kick yourself in the end because you had to buy things twice and it was a waste the first time. If you wanna drag the car, go with some baseline or hpm control arms. More expensive but well worth the extra money for quality and durability.
