it started flashing shortly after i installed new steeda under drive pulleys. it goes off roughly between the 2500-3000 rpm range and kills acceleration. i looked up the diagnostics code and it says cylinders 4 and 7 misfire. is this just a sparkplug issue that coincidentally went off after UDP installation, or is the new UDP's throw something off?
well i think i fixed the problem, i got a new battery and no lights are flashing now. i did get the alternater checked and they did say it was bad. i think because i have aftermarket pulleys it might read that way. anyways thanx for your advice
