Air bag light
Old 06-26-2009, 03:10 AM
thehoggle
thehoggle's Avatar
Default Air bag light
My air bag light constantly turns off and on and keeps blinking as of a week ago. I parked it, got back in a few hours later and the blinking started. It never shuts off now unless the car is off and it's really irritating. I know it wasn't hit...
Anyone have any ideas how to fix it?
thehoggle is offline
Old 06-26-2009, 03:59 AM
asiansensation78
asiansensation78's Avatar
pull the bulb from the cluster?
asiansensation78 is offline
Old 06-26-2009, 09:34 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Don't know if this will help:
Reason 1:
Rapid Continuous Flashing of the AIR BAG Indicator can be Caused By:
* Both primary crash sensors disconnected from wiring harness.
* Main wiring harness not connected to engine compartment wiring harness.
* Electrical Schematic-Rapid Continuous Flashing of Air Bag Indicator
Reason 2:
Continuous Air Bag Indicator Illumination Can Be Caused By:
A diagnostic trouble code which has flashed five times after the ignition switch was turned to RUN (after prove out) and has timed out. Recycling the ignition switch will redisplay the DTCs by flashing the lamp. The DTCs can be retrieved using New Generation Star (NGS) Tester 007-00500 or equivalent.
A disconnected or poorly connected air bag diagnostic monitor which may not push the shorting bar between Pins C2-10, Circuit 57 (BK) and C2-11, Circuit 608 (BK/Y) into its fully retracted position. This shorts the air bag indicator line to ground and causes the air bag indicator to glow continuously.
* A damaged air bag diagnostic monitor.
* Shorted air bag indicator wiring.
* Loss of ignition voltage at Pin C1-6, Circuit 298 (P/O) of the air bag diagnostic monitor.
Either way, your airbags may not be operating at while it is flashing, which means should you be in a accident, they may not deploy. I would take it to ford for diagnoses.
ChalknCover is offline
Old 06-26-2009, 02:13 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
It should flash is 2 increments.. so start the car and the light should flash, pause for a second then flash again. Count each flash and tell me what the 2 numbers are.... (for example, start the car the light flashes 3 times, pauses, then 7 times so its 3,7) Count the flashes and tell me the sequence and I'll tell you the code
WhiteFoxGT is offline
Old 06-27-2009, 02:26 AM
thehoggle
thehoggle's Avatar
awesome, I'll have it tomorrow when I go out. i really appreciate it.
Old 02-18-2010, 10:17 PM
luvemhot
luvemhot's Avatar
White fox I found this post where you asked for the sequence to find a code for an air bag light. Can you look this one up for me it is 3-2 dose it about 3 times and stays solid after.
Thanks so much
Keith
luvemhot is offline
Nick Oliver
10-17-2018 04:22 AM
MusicCity615
09-12-2015 07:05 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
zachary1988
09-04-2015 03:04 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Air bag light
