When to change plugs...
Because it will weaken the amount of time it takes to ignite the fuel and there by rob you of power. (there's technical terms for it all I just do care to look it up.) NA cars usually step up to a hotter plug but in Modular applications, I don't see it helping much with stock compression and stuff.
I wussed out.
I took off the passenger side fuel rail and 1st coil pack and got to looking at the plug waaaayyyyy down in there. Then I turned my head and got looking at the last plug by the firewall on the passenger side. I need to get a good torque wrench and the right spark plug socket before I go for this.
I haven't had any issues, so I am just going to wait until I am closer to 100k. Thanks for the info guys.
Damn, i changed mine just yesterday. As soon as i feel they aren't firing right i change them. They look good except for the 1st one closes to the radiator it was all rusted out. That was my miss i was having at high rpms
here is the plug list for dif. brands.
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
MOTORCRAFT
PART# / HEAT RANGE
NGK
PART# / HEAT RANGE
AUTOLITE
PART# / HEAT RANGE
764s / Stock
CHAMPION
PART# / HEAT RANGE
DENSO
PART# / HEAT RANGE
IT16 / stock heat
