noob question i'm sure
You could definantely pull a 12.9 with the right setup and driving! I pulled a 13.3 with a 1.9 60ft. on my n/a run, with mods in sig. This was done on stock suspension, full weight, and Nitto dr's with a not so great 60ft.
31 spline trac-lok diff & 31 moser axles
BBK LT's
Mac o/r H pipe
Flowmaster american thunder cat-back
3.73's
sct tuned
k&n drop-in filter
tokico front and rear shocks and struts
upper & lower control arms
tri-ax shifter
MT ET streets
rear seat delete (spare tire and jack removed)
zex wet kit 75 shot
are 4.10's bad for driveablity? it's a dd. and what do i need to run the 75 shot safely i know the rpm switch is a most. but is the purge kit, bottle warmer and preasure gauge needed. and should i get an A/F gauge with nitrous?
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
