Anyone in NY?
Link to the manual
TOOL & SUPPLY REQUIREMENTS:
• Factory Repair Manual
• 3/8" Socket and Drive Set: SAE & Metric
• 1/2" Socket and Drive Set: SAE & Metric
• 3/8" NPT Tap and Handle
• Adjustable Wrench
• Open End Wrenches: 3/8", 7/16", 1/2", 9/16"
• Center Punch and a 5/8" Tapered Punch
• Ford Springlock 3/8" Fuel Fitting Disconnect Tool
• 5 Quarts SH/CF Rated Quality Engine Oil
• Oil Filter and Wrench
• Flat #2 Screwdriver
• Phillips #2 Screwdriver
• Heavy Grease
• Silicone Sealer
• Drill Motor
• 1/8", 3/16", 27/64" Drill Bits
• 1/2" Tube Bender (1996-1998 Models only)
• 3/16" Allen Wrench
• Wire Strippers and Crimpers
• Utility Knife
2001 PARTS LIST
2E229-130 Supercharger asy 1
2E128-030 V-2 SQ Supercharger 1
2A036-360 3.60" Supercharger Pulley 1
8R101-001 6-Rib Pulley Retainer Asy 1
4FL111-031 MTNG BRKT ASY, '00-'03 2V GT 1
7A375-178 3/8-16 x 1-3/4" HXHD G8 5
7K375-040 3/8"AN960 Flat Washers 5
2A046-080 Belt, K061080-Gates Saleen 1
4fl011-031 Mach, 2000 GT Mtg Brkt 1
7C080-065 8mm-1.25 x 65 Soc 1
7C080-140 8mm-1.25 x 140 HXH 1
7K312-001 5/16" AN-Washer 4
7C060-050 6mm-1.0" x 50mm HXHD Zinc 1
7C080-025 8mm-1.25" x 25 HXHD 1
4FE014-010 Radiator Pipe-Stnlss 1
7R002-024 #24 Gold Seal Hose C 2
7R003-013 Adel Clamp, 3/4"ID 1
7C010-050 10-24 x 1/2" Soc HD Cap, Zinc Plt 1
7J010-001 #10 Flat Washer 1
7C010-140 10mm-1.50 x 140 Hex Head 2
7J010-002 10mm Washer, Zinc Plated 4
7C010-066 10mm-1.5 x 65 Bolt, SHCS 1
7E010-046 #8 x 3/4" Sheet Metal 1
4FL116-150 2000 2V Idler Ply Asy. 1
4FH111-032 Idler Plt Asy, 2V GEN3 1
4FH016-150 Idler Pulley, 6-Rib 3" Flangd 1
4FA016-171 Dust Cover (Idler Pulley) 1
7C012-020 12mm-1.75 x 20mm Pld 1
2A017-045 Spacer, Idler Plate 2V G3 1
7A375-208 3/8-16 x G8 HXHD 1
7J250-001 1/4"SAE Washer, Pltd 1
7C080-140 M8-1.25 x 140 Bolt 2
4FH112-010 Air intake asy 1
4FA012-012 90° Intake Elbow 1
4FH110-050 MAF Meter Bracket Asy 1
7R002-056 #56 Hose Clamps 6
7S350-200 3-1/2" x 2" Sleeve 2
7U035-000 3-1/2" x 9" Flex Hose 1
7R002-052 #52 Hose Clamps 2
8H040-090 Air Filter 1
7A250-075 1/4-20 x 3/4" SHCS 4
7F250-021 1/4-20 Nylock Nuts 4
7J250-001 1/4"SAE Washers 4
4FK012-040 Inlet Elbow 1
7P750-100 3/4"NPT x 1" Hose Fitting 1
7U033-000 5/8" x 48" Hose 1
7U038-000 3/4" x 27" Hose 1
7U100-052 7/16" Rubber Grommet 1
7P625-002 5/8" Barb 1
4FH012-012 90° Inlet Elbow w/Hole 1
4FH130-026 Oil feed asy 1
7U030-026 1/4" x 26" Oil Feed Hose 1
7P525-067 .525" Crimp Ferrules 2
7P250-066 #4 Swivel x 1/4" Hose Barb Fitting 2
7P125-103 1/8"NPT x -4 x 45° Male Elbow 1
7P250-082 1/4"NPT x -4 x 90° Fitting 1
7P250-034 1/4"NPT Street Tee 1
7P250-036 -4 Flare to 1/4"NPT 1
4FH130-036 Oil drain asy 1
7U030-036 1/2" x 14" Oil Drain Hose 1
7R001-008 #8 Stainless Hose Clamps 2
7P500-003 90° x 1/2" Alum. Tube 1
7P500-020 Tube Nut 1
7P375-042 Male Connector 1
4FH112-020 Discharge Asy 1
4FH012-020 Discharge Tube 1
7S300-200 3" x 2" Sleeve 1
7S275-200 2-3/4" x 2" Sleeve 1
7R002-044 #44 Hose Clamps 2
7R002-048 #48 Hose Clamps 2
7R002-016 #16 Hose Clamps 6
8D001-001 Bypass Valve 1
7U034-016 1" x 3.5" Heater Hose 1
7U034-016 1" x 13.5" Heater Hose 1
7U030-046 5/32" x 52" Vacuum Line 1
7P156-082 5/32" Tee 1
7P100-010 1" Hose union 1
7U133-090 1" x 90° Rubber elbow 1
4fl120-020 ecm ecm chip package 1
4f060-038 38lb. Injectors 8
8F001-265 Fuel Pump 1
4FL139-096 PCV ASY, 2004 Mustang GT 1
4P375-106 PCV Valve 1
7P625-375 5/8" to 3/8" Reducer Barb 1
7U032-016 3/8" Hose (6") 1
7U033-000 5/8" Hose (6") 1
7R001-006 #6 Hose Clamp 4
• Adjustable Wrench
• Heavy Grease
• Silicone Sealer
• Drill Motor
• Utility Knife
2001 PARTS LIST
paypal me $30 and I'll send you a bypass. it's only got 5k miles on it at 10lbs of boost. opens and closes fine. I think I might even still have the flex tube that goes into the fender.
you shouldn't need either of those short plastic tubes either. And hopefully you've done enough research to know to mount you IAT sensor (If not in the MAF) in the engine bay on the intake tube into the TB.
i dont even know what your talking about lol i know nothing about superchargers ill show my friend thats a mechanic what you said lol....i just wanna know what to order from the 1500 superchager thing
