What spark plugs should i use when spraying??
If you want to spray quite a bit you may look at the NGK BR7EF. I ran those in my car. I can't remember exactly, but I either melted a BR7EF or a R5724-8 in #4 cylinder (thanks to having the wideband only on one cylinder bank. lol). When really racing or leaning on the car on the spray, it won't hurt to go cold and narrow on the gapping.
NGK
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
NGK
yeah i used to have an 03 gt before with
Patriot heads stage 3
typhoon intake
comp cams stage 2
75 mm TB/Plenum
Full exhaust
3.73 gears
Diablo tuner
fully built bootom end .40 over bore
and i had it sprayin 175 shot
But i wanted to get some ideas from everybody here how the stock engine with all bolt on mods are doing with 150 since i never sprayed my previous gt with stock motor.
typhoon intake
comp cams stage 2
75 mm TB/Plenum
Full exhaust
3.73 gears
Diablo tuner
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
