bullet stage 2 cams
#31
It's closer to CMS stage 1 cams from what i've seen, but without the higher lift. That will make it a little more friendly on the stock springs.
It will make good power for guys running stock heads and valve springs. This should be a drop in friendly grind, that shouldn't have to be advanced or retarted to fit, and have plenty of ptv clearence.
#32
7 hp??? Try 20-30 hp! CMS stage 1's make this kind of power...why wouldn't these? These are decent specs for someone who doesn't want to change springs, or want's to keep the stock heads. They are also good for the buyer that wants plenty of ptv clearence (since the stock cams can be off alot) and won't have to mess around with degreeing them.
#33
you show me ANY stage 1 cam that will dyno more than 10-15hp to the wheels.. your not even getting a stage 1 spec cam your getting less dude.
#34
I'd be willing to bet with the right tuning these will pull 20+. Naturally aspirated mod motors do well with a fairly low LSA and tight intake and exhaust centerlines.
#35
I've seen several stage 1 cams pull 20+ hp. CMS, Comp, and even Hitech's stage 1 will do that. Maybe not in all cases, but it has been done on several ocassions.
Im all for stage 1s in stock heads and im one of the biggest advocators for them on this site but 20-30 hp...thats stage 2 territory there..
#36
How about we let the OP decide? Hopefully he'll post his results when he's done.
#37
#38
theres not much more advancement they can do with a 2v cam that they havnt already done..
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
