wiring air/fuel ratio gauge!?
Old 07-30-2009, 06:38 AM
Gunso04
Gunso04's Avatar
Default wiring air/fuel ratio gauge!?
how do I wire a air/fuel ratio gauge in 2001 mustang!?
Gunso04 is offline
Old 07-30-2009, 06:52 AM
99 GT vert
99 GT vert's Avatar
which gauge????????
99 GT vert is offline
Old 07-30-2009, 08:05 AM
Gunso04
Gunso04's Avatar
it´s a gauge from Auto Gauge!
this one
http://www.autogauge.com.tw/web/prod...45AAFRCL270-SM
Gunso04 is offline
Old 07-30-2009, 11:49 AM
Gunso04
Gunso04's Avatar
has anyone wiring diagram for these gauges!?
Gunso04 is offline
Old 07-30-2009, 03:12 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That looks to be just an uncalibrated narrowband gauge. It will mostly just provide a lightshow with little to no tuning value.
The easiest sensor to tap is the passenger's side, it is a Gray/Light Blue wire at pin 5 of C133.
You'll need a 10mm socket to remove the M6 clamp screw that holds the connector together, then cut back the wrapping on the harness going to the top-half of the connector. Find the Gray/Light Blue wire and either strip some insulation from it and wrap as solder a lead, or use a 3M tap (fill it with dielectric grease before clamping it on).
I have diagnostic taps into this line and also the driver's side front sensor circuit--a Red/Black wire at pin 11 of C139 (the unlabeled connector just to the top and slightly right of C133 in the diagram below, between C133 and C130).
cliffyk is offline
Old 07-31-2009, 04:32 AM
Gunso04
Gunso04's Avatar
thanks
Gunso04 is offline
Jb145700
08-21-2022 06:37 AM
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
Quick Reply: wiring air/fuel ratio gauge!?
