Oversized tires are OK --->
Saw myself a Stang a bit ago with some 295/35/18"s on an 8" wheel:
Little hard to tell from cell pic, but both rear tires have deep cracks all the way around the tire due to excessive roll-over of tread. I am always harping on running correct sizes and this is why
Jazzer says... crack is wack
I thought it was fender scars too, but the wheels look pretty far from the edge of fender, so I am not sure. Looking up very close, you can see what looks like stretch marks from the strain of the tire curling over the edge. Could be a combonation of fender and strain I suppose.
Jazzer
EDIT: This is also an 8" wheel and have also seen a 315 on an 8" wheel and would rub like a big dog, depending on off-set. I will see if I can dig up that pic
Jazzer
my guess is fender rub, but it doesnt matter because that is just ****ing stupid...you get no performance gain, and it looks like ***, actually you lose performance, increase bad tire wear and if you went around a corner really fast youd probebly unseat it from the bead. I dont know a tire place that would have put that on for you....
