Finally got some pictures
Dude dont take comments serious about your kit , I give you credit on the work and effort and the money you put into your car , you just gotta respect people's opinions on certain things they do like and dont. Honestly I dont think no one was being rude about it just giving there train of thought.
No not yet, I have some work to do with the rear end before I go in for a tune.
Yeah, I have looked into some of the other kits. Honesty awhile ago I was thinking about just switching back to the original body pieces, but they were fubared while they were off of the car... I will eventually change out the bumpers for something else, however it is not as high on my priority list as getting the car to run the way that I want it to.
Also: Thanks for being mature about the situation, I appreciate it allot.
As far as mods go... I have a number of things done, however it is still undergoing surgery if you know what I mean.
I have the Vortech v2 s-trim supercharger, steeda boost pipe, larger K&N filter, 75mm throttle body, 75mm upper intake plenum, 38 lb/hr injectors, 255 lt/hr fuel pump, 4V coil packs, NGK plugs, fluidyne aluminum radiator, aluminum flywheel, street/track clutch, steeda adjustable clutch cable, T56 6 speed transmission, steeda shifter, ford racing clutch fork, aluminum driveshaft, cross drilled/slotted brake rotors, diablo tune, Borla 3 inch catback, battery relocation, steeda functional wing and a rear seat delete kit. I may be forgetting a few things but that is what I can get off the top of my head...
Post the pics back up. If you can't stand the heat, stay out of the fire. You have put a lot of money in your car. You should be proud of it no matter what some other guys say. Yes some people over do it, but it's your car and you have to like it at the end of the day.
REPOST PICS
