Car care in Ohio weather?
I'd really like to drive my car all winter but i know it can damage. I was looking for some tips to prevent engine damage and etc. Such as if i should run alittle rich or stuff like that.
If you are set on using your car in the winter, I'd say a good set of snow tires and frequently rinsing the car off. Particularly if they use a lot of salt in your area. Salt can do a nasty job under the car, where you can't really see what's going on.
what part of ohio are you in
also not sure if this is used all through ohio but in my area they use a liquid ice melt/prevention that is very very hard on metal parts of the car make sure you find a way to get the underbody clean and wax it often
If you truly love your car, find a winter beater to take the punishment from the snow and salt. If you have to drive your Mustang in the winter, clean it often (which can be a problem on days when the temperature is below freezing).
Mustangs suck ball$ in the winter , I drove one a few winters ago and was getting stuck all the time even with a good set of all weather tires rated 8.5 in snow. If I was you I would buy a 500$ beater and store the stang plus salt is bad for your car.
