Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Oxygen Sensors
Step by step instructions for do-it-yourself repairs
o2 sensor questions
The pigtail lengths are different, and the connectors are keyed, I don't remember what's what but placement listed on most FLAPS' websites.
The key in the connector can be cut off to make a "universal" fit sensor, the pigtail length is another issue--too long is OK, however too short can present problems ...
If your downstream 02('s) are/is bad you SHOULD be getting a Catalyst efficiency code.
The job of the Downstream (Rear) O2's are simply to measure the efficiency of the Cat's. If the voltage is wrong, a Cat Eff. code is thrown.
However, if it's an Upstream you should be getting TERRIBLE fuel mileage, the possibility of other symptoms and NOT a Catalyst Efficiency code.
well everyone is saying that it is a downstream one, but i am not getting any other codes... my gas mileage seems pretty ****ty right now...so whitch one should i change out..i dont want to buy all 4...it is running those two different codes...someone help me...all of this is just confusing me even more and more
Well according the the information in the listing, it will work for the front AND rear locations. So I would assume you would be safe there. Honestly though, if you can afford it, I'd replace em all. But thats just me.
TfcCDR
09-14-2015 12:08 PM
