Buying a stang need help!
he doesnt love her because he found a bargain on a car and wanted to know if it can be fixed? for 3k its a steal assuming the rest of the car is in good condition...pick up another PI motor for $500 and throw it in if that one ever takes a ****.... ide put a junkyard timing cover on it, make sure the chains and everything look good and replace the tensioners while i was in there, and drive it like that...if the chains broke causing the cover to crack, then the valves would be destroyed and the car wouldnt run right...so if thats how the cover broke, then its obviously been repaired, minus a new cover....the car is fixable, and for 3k its a steal if the rest of it is nice
not everyone can afford to spend the same amounts on a car...if hes got 4k to spend, ide rather drop 3 plus some work into a nice stang than to buy a beater civic with 400k miles
this is the stupidest comment ive read in awhile
thanks, that was my point. im a broke college kid, I totally understand the whole budget thing. you can find a s95 with 70k miles on it for 3k and in good shape.
motors are cheap, $500 plus $500 install....so 4k for a new edge gt in good condition...even less if he can do the swap him self
if the timing chains broke that motor would be ****ed...he says the car runs, so it has either been repaired or that is not how the cover broke....
why does everyone assume it needs a new motor if the car runs?
