17x9 17x8 staggered
#31
Jazzer
PS. I call a ban to HUGE pictures in threads because I have to scroll the screen laterally to read the darn thing
#32
I am thinking about these tires. the 17x9's have 24mm will I hav e any rubbing problems? and the 17x8's are 29.5mm. I was going to go with BFG g force but I do not like the tread design and they have bad reviews
http://www.americastire.com/dtcs/fin...=ORPINT&cs=275
#33
it depends on what you want. bigger tires are more expensive. Staggered means you cant rotate...again more expensive. If you like the meaty look out back then go with wider tires. if you drive many miles then cost is def something to consider. Tires are not cheap and being able to rotate is a plus.
You can to rotate the tires. You just do it side to side. Most places will charge a one time fee to dismount and mount the tires. I'm running 10.5's on the rear and had them rotated not to long ago, and before someone says thats stupid to rotate from side to side your wrong. You rotate tires to keep any unusual wear patterns from forming. Also clearance won't be a problem heres a pic of mine.
