Anybody sparying 200 shot of nitrous???
uhm i have the car with a diablo tuner and all the basic bolt ons. 75 TB, plenum, 3.73 gears, intake, pulleys, full exhaust.
Im planning on goin to dyno soon, i need to see how she is running.
get it dyno tuned to see what its actually putting down before upping the shot... 400-450 is the breaking point on these cars, so if its an all spray car, i wouldnt push it all the way... if you make around 250 with your bolt ons, a 200 wet shot is going to put you in the danger zone for sure...is your kit wet or dry?
If your spraying a true 175 shot untuned, you have a ticking time bomb under your hood. You need a dyno tune asap.
I think anyone running any sort of F/I without a tune is insane let alone a ridiculous shot of nitrous, that engine has got to be on its last leg.
you need to get dyno tuned for the 175 shot...diablo tuner canned tune isnt enough...you will hurt your car eventually running without a proper tune
Why is it so bad that he doesnt have an almighty dyno tune?
if you pull the necessary timing(exactly what a dynotuner will do) your fine..
The block may give out just from the sheer torque numbers but just because someone doesnt get a dyno tune does not mean jack didly.
