500hp goal lil help on where to start please?
Comments on the parts I already have because like i said got most part cheap or free and want to know if theyre all worth useing and are quality part or is there something better out there?
Sry if this is a real nooby question but i do know that it will run alot beeter with a good tune from a shop but doesnt the blower come with a stock tune i can run till i have the time and money to drive to a shop to have it tuned?
I would get it professionally tuned. Look around for a shop and get some prices. I would say Dyno tune is A MUST...
How much cash do you have to play with? That will determine which route you take to get the 500whp goal... as in keeping stock heads, Going with new heads, Ported heads, Cams. Also dont forget your rear end needs upgrading, along with Fuel system.. both end up costing around 1k each..
In my opinion the "canned" tune that comes with a kit is only good enough to let you carefully drive to a tuner to get it checked. My "canned" tune caused the car to run lean at higher rpm. The tuner was able to fix it by adjusting the the A/F ratio rich mid-range. It took a MAFia and a second tune to get it set correctly.
Whats your opinion on the kenne bell chip tunes? I've heard opinions from both sides. I've had many KB owners say they had the A/F checked and it was spot on and they drove around for months, sometimes longer before getting it dyno tuned due to extra mods added, and it pulled great. I've also heard its really just a "meh" tune all around and that theres a good 30 RWHP ready to be unlocked at the same boost level from a dyno tune.
