Rear Wheel Wobble / Loose Hub / Bad Bearings
My rear driver side wheel started to wobble. It makes dinging sounds when I hit bumps and such. I removed the tire and pulled on the plate that holds the wheel studs and it has a little bit of give to it. You can push it in and pull it out slightly, and it makes a dinging noise when doing it so I am almost 100% sure this is my problem. I have heard bad bearings could be my problem but I'm still trying to troubleshoot it before making a decision to replace them. Any help would be appreciated it.
Thanks
Thanks
