Are my cam gears bolt on?
Old 10-12-2009, 09:57 PM
01MGGT
01MGGT's Avatar
Default Are my cam gears bolt on?
Title says it all. If I get cams are my old gears pressed on or bolt on so that I can install them on the new cams? I have a 2001 that is an eaerly one in some ways. It has the newer water pump pulley but has aa t45 (I think it's t45 because I have a 6 under the TA code and not a K) so I ain't sure.
01MGGT is offline
Old 10-12-2009, 10:22 PM
pcs
pcs's Avatar
i know my windsor 99 gt has pressed in gears and when i did the cam swap i had to buy the bolt on gears. i believe all the windsor have pressed in gears and the romeos have the bolt on gears. check your valve covers 13 bolts should be a windsor 11 bolts romeo, check your 8th vin # too. x = windsor and w = romeo
pcs is offline
Old 10-13-2009, 02:37 AM
01MGGT
01MGGT's Avatar
hum my VIN seems to say I have a windsor engine. Can anyone else confirm I need to buy cam gears? Are the cheap enough new or will I need to source used ones?
01MGGT is offline
Old 10-14-2009, 06:12 AM
01MGGT
01MGGT's Avatar
Any more help guys? What do the cam gears and bolts cost? Part numbers?
01MGGT is offline
Old 10-14-2009, 03:02 PM
01MGGT
01MGGT's Avatar
Ok after some research it appears I do in fact need the new cam gears to install on the aftermarket cams. So any help finding these gears and bolts would be great. I know someone has had to do it
01MGGT is offline
Old 10-14-2009, 03:26 PM
amoosenamedhank
amoosenamedhank's Avatar
I would just get the stock Ford cam gears. I don't really like the idea of adjustable cam gears. Call Tousley Ford, they are one of the largest Ford parts dealers and they give a lot of forum discounts out.
amoosenamedhank is offline
Old 10-15-2009, 05:18 AM
01MGGT
01MGGT's Avatar
That's what I am trying to figure out. If I buy hitech stage 1's will I need to buy press on or bolt on cam gears? Is there even a difference? Are the part numbers different?Can I press the cam gears on the hitech cams myself somehow? If not what is the cost? I didn't plan to run adjustable cam gears
01MGGT is offline
Old 10-15-2009, 07:59 AM
mrtstang
mrtstang's Avatar
I'm not sure which ones you have or want, but Modular Head Shop has them both used and new. Give them a call.
2V matched set of cam gears
Item price $95 used or $145 new
The stock cam gears are notorious for poor degree tolerance and are found typically from plus or minus 4 degrees with some even further beyond that. We pair match these gears to a typical 0.5 degree spec on a stock spec motor.
If your heads and/or block has been decked/surfaced/milled then its about 0.5 additional negative for every 0.008" of material removal. We have not found much difference with old vs new timing chains and/or the crank gears. All the variance seems to be only in the cam gears.
Phone: 321-262-1132
Email: info@modularheadshop.com
mrtstang is offline
mtgldr
02-03-2024 09:00 PM
maestro1024
09-21-2015 02:40 PM
ctgreddy
09-20-2015 08:35 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Are my cam gears bolt on?
