Guestimate my HP game.
I know some people don't like these threads, but im anxious to find out what numbers it will put down...
ok so currently I have the following:
PI H/C/I (I cleaned and port matched the intake side and mirrior finished the exhaust side)
Accufab 70mm TB
Mac LT's
Mac O/R H (welded the middle together to prevent leaks and grinded down the lip in the H part)
4.10's (doesn't matter)
24lb injectors
Sniper software 93 using: 10:1compression ratio, bumped 2 global, .5 low, 1 mid, 1.5 high
180 stat
What do you think I will get for a hp number ball park?
my guess was 250 but seeing some real numbers its from anywhere from 230-260's...
EDIT: I'm getting it dyno'ed on OCT 24th so I'll update this when I know my numbers for sure. I'm hoping that there will be a tailpipe wideband so i can tune for fuel.
Accufab 70mm TB
Mac LT's
24lb injectors
180 stat
