judge my suspension setup
Old 11-09-2009, 04:26 PM
boduke0220
boduke0220's Avatar
Default judge my suspension setup
Having a broke hand means i cant do alot..or drive my car ..so its time for car parts wishlists!
trying to figure out a streetable setup capable of 1.6's or lower. is the spring rate too soft? who makes good control arms?
PA Racing coilovers, A-arms and K-member with 150 lb springs
Lakewood 70/30’s and 50/50’s
Aluminum driveshaft
31 spline rear end.
V6 wheels with drag radials
Control Arms?
boduke0220 is offline
Old 11-09-2009, 07:42 PM
dimebag
dimebag's Avatar
I went low low 1.6s on this...
90 10s
50 50s
Summit cas
Fox 4cyl springs in the front
4.10s
235 60 15 dr
dimebag is offline
Old 11-09-2009, 07:50 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
boduke... are your goals STRICTLY 1/4 mile or do you want good DD handling for twisties and such?
Jazzer
Jazzer The Cat is offline
Old 11-09-2009, 08:30 PM
boduke0220
boduke0220's Avatar
it should still be DD'able but i dont care about hadleing so much
Old 11-09-2009, 10:23 PM
ddmsgtr1
ddmsgtr1's Avatar
I've got UPR UCA/LCA's (sphericals) being installed this week along with a baseline ARB and steeda FLSFC's. I'm hoping to hit the track next tuesday, I'll let you know what I'm cutting with my nittos.
ddmsgtr1 is offline
Old 11-09-2009, 11:58 PM
02stangdude
02stangdude's Avatar
do u want to b able to cut 1.6 all day even on the street or just at the track? i have adjustable tokico shocks/ struts and tokico spirng that lowered the car 1 1/4 plus upr upper and lower controle arms. with mickey thompson street slicks mounted on v6 wheels i cuz a 1.77 60 my first time at the track with them on the motor. im pretty sure i can get that to a low 1.7...but when i do more suspension mods im gona do strage 10way adjustable so i can set it for the track and the street. im real happy with my upr uppers and lowers and i would hope the strage shocks/struts will help a little more so that would b a decent set up for you right there....strage shocks/struts, upr upper and lowers, set of good tires and im not sure what springs but im sure that right there would get u damn close to a 1.6 60ft
02stangdude is offline
Old 11-10-2009, 07:15 AM
Jazzer The Cat
Retired Moderator
Then just about any aftermarket LCA will be fine, but would recommend something heavy duty as it will hold up better on long-term launching. You are gonna want adjustable UCA's to address pinion angle, but would recommend a spherical end on each LCA/UCA if you have ANY thoughts on improved handling. They can only help your launches, but will degrade cornering without them.
As for springs/shocks.... have no idea, as I a quarner guy
Jazzer
Old 11-10-2009, 11:49 AM
dimebag
dimebag's Avatar
springs.... do fox 4cyl up front and stockers in the rear... if ur doing coilovers, do a 165-14 spring up front.... stock rear
dimebag is offline
Old 11-10-2009, 03:02 PM
ddmsgtr1
ddmsgtr1's Avatar
If you want the ultimate setup, do coilovers, and get double adjustable shocks for the rear so you can adjust rebound and compression separately. Your talking about a serious investment at that point, though. Ripping the front sway bar off never hurts either.
ddmsgtr1 is offline
Old 11-10-2009, 03:12 PM
boduke0220
boduke0220's Avatar
would h&r supersports work for the rear? theyre pretty stiff, maybe too stiff though i think itsa 250-300 progressive rate.
Quick Reply: judge my suspension setup
