Comp Cams XE278 fit a Stock Block?
Old 11-11-2009, 01:31 AM
02Stang89
02Stang89's Avatar
Default Comp Cams XE278 fit a Stock Block?
Im just wondering if anyone knows if Comp cams XE278 which is a pretty wild cam and has 242/246 duration @ .050 and .550/.550 lift would fit a stock 02 Mustang GT short block? My friend just gave me these for a really good deal that I couldn't pass up. I was told that the piston to valve clearance might be a problem. Any one know for sure? Thanks
02Stang89 is offline
Old 11-11-2009, 08:13 AM
mrtstang
mrtstang's Avatar
The xe278ah right? That's not a small cam for your car. They will hit at those specs. There isn't much clearence on the stock PI head motor.
mrtstang is offline
Old 11-11-2009, 08:21 AM
aode08
aode08's Avatar
no it wont work, it will hit at high rpm's or a mis-shift
aode08 is offline
Old 11-11-2009, 08:48 AM
sainthk
sainthk's Avatar
I have these very cams and you will need to cut valve reliefs in the pistons.
Just like aode said, at high rpm or even red line they will hit.
sainthk is offline
Old 11-11-2009, 09:12 AM
teej281
4.6L Section Moderator
teej281's Avatar
Ford really should have taken into consideration that people would be heavily modifying these cars after purchase and given more ptv clearance. I mean seriously, look at every other mustang ever made...they've all had a religious following of modifying the cars while trying to keep the bottom end stock. They should really learn something from that.
teej281 is offline
Old 11-11-2009, 09:21 AM
H0SS302
H0SS302's Avatar
stuff like that drives the price of the cars up.. Ford is all about profit so they skimp on stuff.
H0SS302 is offline
Old 11-11-2009, 10:06 AM
teej281
teej281's Avatar
What ways are there to giving more PTV clearance than valve reliefs???
teej281 is offline
Old 11-11-2009, 10:14 AM
mrtstang
mrtstang's Avatar
Running a different valve is one way. Different or ported heads would change this too. You could also create more ptv clearence by retarding the cams, but it will cost you power.
mrtstang is offline
Old 11-11-2009, 10:30 AM
BraMas
BraMas's Avatar
So how are you going to put cams in a short block? last time I checked the cams in a 4.6 are in the head and a short block means block and rotating assembly with no heads on it.
BraMas is offline
Old 11-11-2009, 01:50 PM
02Stang89
02Stang89's Avatar
Thanks for the info guys. Yeah I meant long block not short block sorry. In the spring Im buying Trick Flows 2V heads and having Fox Lake port them even further. Those heads support a cam with a lift up to .600. So these cams would fit in those heads right? Thanks again guys!
Quick Reply: Comp Cams XE278 fit a Stock Block?
