Supercharger install
I'm about to install a Vortech v-1 supercharger on my 02 mustang, but it didn't come with injectors or fuel pump. I can't find hi-flow pumps only oem replacement, so do I have to change the pump because the flow of a stock pump is 60lbs-70lbs, which is about what i need: 255lph. And are 42lbs injectors to big for set up? It ask for 38lbs injectors.
I have a novi 2000 I'm using 42lb injectors and a focus pump. I'm running 9lbs of boost. My fuel pump is at 100% duty cycle in 4th gear at 6000 rpm's.
http://www.kennebell.net/media/artic...WFORENSICS.pdf
This is worth a look at. I wish I would have known about this article before I decided on my fuel setup.
I have a V2 with 42lb injectors and a Focus SVT. If I was going to do it again, I would put in a larger pump. My Focus pump is at 100 duty cycle around 5,600 RPM and limited my HP gains.
I see in your signature you have underdrive pullies. I do not know why, but everyone says you need to swap back to stock when you go supercharged. maybe someone else can chime in.
