4.5" Backspacing Welds?
??? before or during launch is the car near the ground? If before, you obviously have the car too low, if during then you need to check your pinion angle and probably run a stiffer rear spring and/or an airbag.
You don't want a bunch of drama on launch (squating, twisting, etc) you want it to plant the tires and go. Even though the 28's are tucked with a 5.5" bs you can see I would still have room with a 4.5"
this is too much twisting
I just sold a pair of them and know what they go for, that's why I was thinking scam. It may not be, but consider this... it's going to probably cost him $40+ just to box up and ship, why would he only pocket $60? If he's not trying to take your money or pawn off some bent wheels then that's one hell of a deal! I can hosetly say that I've NEVER seen them THAT cheap!!! Just be careful.
What's your revlimiter set to and what do you plan on your car trapping? I don't know if I've asked you this or not before but what part of La. are you from?
Yea I was gonna check some more on the wheels being they are so cheap, was just wondering if they would even work.
Oh, and I'm in the Baton Rouge area, I live in Brusly, right across the river from LSU
Well, I think I will be trapping around 115 or so when I go intercooled and put the new clutch in. I went to the track right after I put the S/C on this summer and trapped 110 and was on the rev limiter (rev limiter set to stock level). And that was on a super rich tune (was 10.0:1 during WOT) and my clutch was slipping pretty bad.
I'd suggest just bumping up your revlimiter a couple hundred, unless you really want 28's.
my car is actually 1/2'' higher than stock ride height. here is a list of my suspension mods:
bbk polished strut tower
eibach drag springs with airbag (rear)
eibach coil overs 14" springs 175 spring rate (front)
lakewood 70/30 shocks (front)
lakewood 50/50 shocks (rear)
lakewood driveshaft safety loop
upr products shark caster camber plates
upr products bumpsteer kit
upr products chromoly k member
upr products chromoly a arms
maximum motorsports extreme duty adj. lower control arms
and off the line it squats
09-17-2015 07:57 PM
cardsrus1
19
09-15-2015 08:37 AM
