Removing cats
either turn it off with a handheld tuner, get MIL eliminators, or buy that programmer that only turns off the engine light. I'd probably get the handheld tuner so you can use it for other things too and it's guaranteed to get the light off compared to MIL eliminators.
You need the 2 most upstream O2 sensors on both banks regardless (the ones before your converters now).
The two after the converters may or may not give problems if they aren't present. I know a handheld tuner will keep the CEL off due to no converters IF the sensors are connected and installed. But if you unplug these sensors I don't know what will happen.
I unplugged one of mine to install a wideband o2 sensor where the stock sensor is supposed to go and my CEL went on but I got someone to help me with my tune and shut it off.
