Do fogs come apart?
Do fogs come apart?
Hey guys I dont post over here much, and I never mess with my DD, so Im a newb. But anyway, one of my fog lights has some moisture on the inside of it. Do 99-04 fogs come apart so I can clean/seal it? I couldnt find much when I searched. Thanks!
Im not sure, but you can use a rag and stick to swab the inside of the housing. Then put some rtv where the lens and housing meet. And make sure the light bulb connector is making a good seal.
Thank you for the quick reply. I thought about doing this, but I want to prevent it from building up again. I just dont know if it is coming through where the bulb is, or if the light comes apart and its leaking around the seal? Im sorry for posting something like this; I just really haven't had any time at all to mess with it. Thanks again
Take them out and pour as much water as possible out. Then put them in the oven at like 200-250 for a few minutes to get the rest of the moisture out. Alternatively, you can use a hair dryer, but it takes a bit longer. Then RTV around the edge where the lens meets the housing.
If you still get water in them, then it's probably the seal around the bulb. Not much you can do except replace the bulbs and hoping they seal better. You can RTV around the bulb, but changing them will suck cause you'll have to scrape the rtv off every time you change them.
Diode Dynamics
28
05-26-2022 12:02 PM
