Quality of cams
Nick (the owner) has done his homework, and has designed grinds that combine a lot of the best qualities of cams like Hitech and CMS.
less restriction will make your setup more efficient and therefore save gas per capita if you understand what im saying. Like with those heads and stock everything else you would probably get better gas mileage. But why would you do heads and not do cams and other things to take full advantage of the heads you just bought. But probably considering that you go to stock heads with stock cams to TFS heads and stock cams with a blower you might get better gm.
junior04
09-28-2015 10:53 AM
mungodrums
Suspension
09-24-2015 10:12 PM
