gracias cliff! so i don't also need 2 replace my :distributor ignition pickup and or ignition control module and or coil connectors?
since you know the reason why I'm replacing the ignition in the 1st place
thnx cliff again
now that you know why i wish 2 replace my ignition, would it be a good idea to also replace: distributor ignition pickup and or ignition control module and or coil connectors?
Yes, you should replace it all, the auto parts store can help get you what you need. Might want to top off your blinker fluid too, if it's not been changed in a while.
