Vortech vrs. Procharger, what do you think??
#21
See my tuner disagrees big time. He said the imput shaft is larger and stronger on the procharger and the actual impeller is made stronger or something. I may have messed up what he said though, its been awhile since we talked about which blower to choose. There was like 4 or 5 points he raised including once you add the intercooler for a vortech you are at the same price for a procharger.
#22
so when i do actually get a blower ill belloking to get the inter cooler with it....
i like the air-air cooler that procharger offers. simple and looks reliable.
i dont like the air-water-air cooler vortech offers. if im racing i dont want to have to keep putting cold ice into the tank to keep good low times at the track.
#23
the air to water is "better" but for a street car the air to air is fine, it works and its extremely reliable. Vortech is cheaper and better and will make more power, the p1sc had an advantage with the step up ratio in comparison to the v-1, but now the v2 puts that to a tie. Neither are bad, but ease of ownership is way better on the vortech.
#26
The tuner I've been talking to does alot of prochargers and novis. I mentioned the belts to him, he says he's never had a problem and is convinced if your chewing belts up you have a problem with the pulleys lining up.
#27
I have been procharged for 3+ years now. I might be able to shed some light on a couple things mentioned thus far. First the leaking issue is caused by the user not changing the plastic seals for the drain plug and the on the fill plug. Its really that simple if you change the seals that get wore out it won't leak. I also agree that if your chewing up belts you have an alignment issue. I have never had any of these or any other problems with my procharger. They have awesome customer service and amazing quality products. Ever been to a NMRA race? Procharger is def the leader in the market. You just don't see many race cars with a kenne bell or vortech blower. But u def see a lot of Procharged ones for good reason. Procharger is the only choice in centri blowers.
#28
I have been running a ProCharger for over 2 years and over 50,000 miles without any significant problems. I have never had a belt shred. I have only changed my belt once. That was 30,000 miles ago so I think I need to change it again. A mechanic told me my pulleys weren't lined up properly just after the ProCharger was first installed. A washer behind the idler pulley solved the problem.
ProChargers do have a tendency to leak if they are overfilled. They seap oil out of the fill screw and a little bit of supercharger oil goes a long way. Mine's just started doing it again because I overfilled it last time. ProCharger sells their own supercharger oil. The bottle says to use the entire bottle for a P-1SC but you don't want to do that. You use about 85% of it because you want the oil level to be just below full on the dipstick.
I read a post once from a guy whose Vortech hyrolocked his motor bending a rod because a seal went out and it pumped engine oil into the cylinder. Malfunctions can occur on any mechanical device.
Both are good superchargers. I do not regret getting a ProCharger.
#29
Have you seen a ProCharger bracket? How do you melt a heavy metal bracket without setting everything else on fire? I doubt that this is true.
#30
I've had a vortech V-2 S-trim for 2 years now... I installed it, and yup, that's it. Haven't looked at it or thought about it since.
I also bought my head unit used, so I have no idea how many miles are really on it. But she's still running like a champ.
