Throwing car in "N" while driving
I catch my self putting my car in neutral and gliding when i see a red light or when im about to stop... is this bad for the trans or engine in anyway or does it not affect them any?
Note: Usually going around 40-50 when putting it in neutral to glide...
I'm sure thats fine to do if you are 100% sure you are gonna come to a complete stop. The problem is sometimes if you think you are gonna cruise to a stop on a red which suddenly turns green then that will be troublesome since I am pretty sure putting it back into D while in motion is not a good idea.
1. Move the lever too far, by mistake to throw that baby in "R" and go bye bye to the trans or rear end
2. Forget you are in "N" and will attempt to go through the intersection that has turned green just before you get to a complete stop could be a bit embarrasing
3. Do the above, but have music on and not paying close enough attention and gun the gas to show off to the fine looking gal on the corner you are trying to impress with your manly ride
4. You are going through said intersection and need to gun the gas to avoid get plowed by a 3 tractor semi loaded with 10,000 tons of nitroglycerin and, along with 300 innocent victims, among which is the girl you are trying to impress, all die in a huge firey ball that can be seen by the Russian spacemen currently orbiting the earh
Other than those few things... it is pretty much OK
Jazzer
