what is the difficulty of replacing the clutch on an 04 GT? Do I have to take the whole tranny out? And anybody got any "shade tree" tech advice? I have an 04 gt with several bolt-ons and 4.10 gears. what would be a good clutch that wont break the bank but has ample clamping force? thanks
what does it usually cost for a clutch for the 04? and if you change it out, about how much does it cost for install? Im sure I should start planning for mine, I have about 50k on the car. that sound about right?
Is your clutch slipping? If it isn't I wouldn't worry about changing it out just yet.
Spec 2 clutch kit runs $334.99 on AM.com. Centerforce clutches are good but run a little more.
My clutch install cost $1100 I think... Stage 2 SPEC $350, Alum Flywheel SPEC $350, UPR quadrant + firewall adjuster, so about 3-4 hours labor at 60 an hour.
