What kinda dyno was it?? My dads car was put on a mustang dyno and it said it only put down 320 hp? And its close to 400 easy. But the tranny issue may be it as well.
thats what i was thinking, those cams look pretty agressive, tuner probably had to retard the timing so much you lost power? sounds like your combo is good at making power at 6500+rpms..which your motor can rev to
Wrong. The cams are just fine for the stock bottom end. You just can't completly utilize those cams on a stock bottom end. The tuner sounds like he doesn't know what he is doing. Are you throwing any codes? Is your CEL on? Post your dyno graph.
