78mm throttle body?
Old 01-05-2010, 12:27 PM
jbolo05
jbolo05's Avatar
Default 78mm throttle body?
will the 78mm throttlebody work on my stock 01 gt or is that too big?
jbolo05 is offline
Old 01-05-2010, 01:07 PM
lizzyfan
Underboss
lizzyfan's Avatar
Though someone is gonna chime in it's too big, it will work fine
lizzyfan is offline
Old 01-05-2010, 01:12 PM
jbolo05
jbolo05's Avatar
so would u reccomend somthing smaller? like a 75?
jbolo05 is offline
Old 01-05-2010, 01:16 PM
jbolo05
jbolo05's Avatar
also is it a waste upgrading the whole thing or is the upper fine?
jbolo05 is offline
mrtstang
mrtstang's Avatar
I agree with lizzy, that it'll work fine, but you would be better suited to a 70 (75 at most) if you are just doing bolt ons.
It's best to do the tb/plenum together. You will gain a little more.
mrtstang is offline
Old 01-05-2010, 01:26 PM
lizzyfan
Underboss
lizzyfan's Avatar
That's the beauty and selling point of this bolt-on is that it's the T/B and plenum in one and not a bad price at all
lizzyfan is offline
Old 01-05-2010, 01:35 PM
mrtstang
mrtstang's Avatar
Yep, and the price is great as well. I just wonder if it's a good quality piece. I haven't heard to much about them yet.
mrtstang is offline
Old 01-05-2010, 01:40 PM
02stang2113
02stang2113's Avatar
It will work but it isnt really needed.
02stang2113 is offline
Old 01-05-2010, 02:05 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Overkill, but it will work fine.
ChalknCover is offline
Old 01-05-2010, 02:20 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
FWIW, my 2¢ worth...
78mm is too big for any non-intake/cam/heads n/a engine--you will lost charge velocity at WOT up to 5k rpm or so and that will cost you power.
The OEM 65mm was chosen to maintain charge velocity to boost efficiency (think fuel economy) however it is a bit too small for 5k+ rpm. A 70 is 20% higher capacity then the OEM unit and is all that's needed to get things flowing strongly up to red line, without hurting anything.
A 75mm TB is 40% larger than stock, the 78 is 50% larger--great for n/a but less than optimal for a bolt-on n/a engine...
cliffyk is offline
Quick Reply: 78mm throttle body?
