AEM wideband system install
Hey guys, i installed this a few weeks ago and finally got around to post them.
http://i381.photobucket.com/albums/o...g/IMG_1973.jpg http://i381.photobucket.com/albums/o...g/IMG_1974.jpg http://i381.photobucket.com/albums/o...g/IMG_1975.jpg For now I installed the wideband in one of the rear O2 areas, this is ok becuase I'm running an O/R pipe and the cats wont mess with the readings. Very easy to install and i think it looks good on the steering column. What do you guys think? Hoping to get some better fuel tunes in it after winter. It idles at 14.5-15ish after it warms up a bit. Normal idle values? I know 12.8-13.2 at WOT, but I'm unsure of a good idle, curse values. |
Looks good that is a good meter I also installed in a rear o2 hole. 14.7 for idle and partial throttle but a range like you have is perfect.
Originally Posted by vanquish
(Post 6747974)
Also installed that hurst shifter handle a little while back, great for slamming gears :) |
No offesnse, but why do you need a wideband?
looks good! good luck at the track
Originally Posted by GTRACER88
(Post 6748602)
what made me get one was I was getting my car dynoed and they have a tail pipe wideband there and they measured it at around 15.5 at WOT which is dangerous for pinging. The guy there was nice enough to let me try a few tunes to get it lower but now Im running rich (12.2). The Pi swap messed with my AFR from the better flowing heads/intake. |
Ah gotcha. I bought the same one. I will install it eventually... just sitting in the box for now.
looks nice, I have the same one and I also used the o2 hole as well.
very nice piece, exspensive...but worth it
i also used the rear 02 hole |
Is it possible to use the rear sensor hole on the stock exhaust setup with out throwing codes?
Im wondering because I drilled and welded the bung but not in the + 10 degree from level. Now my AF values are really wacked out, and maybe its because of this. |
