Lil update 500 HP club UPDATE NUMBERS!
Well folks looks like the 500 HP club is gonna become a reality! Long story short getting a set of stage 2 heads and stage 2 blower cams from Nick at Modular Head Shop. As some of you remember when I got my MMR 900 the pistons were not flycut (I blame myself and MMR for not mentioning it) so to be able to run Nick's cams I'll need aftermarket intake valves. Upgrading the fuel system to twin 255 pumps, 60lb injectors, aftermarket fuel rails, external fuel regulator, and of course larger fuel lines. Still pondering whether or not to do an overdrive crank pulley.
I'll keep everyone updated!
DO EET!!! DO EET NOW!!! You should up the boost. With just the heads and cams though, you'll be over 500rw and then to add the OD crank pulley you'll be at like 550rw...but you know this already. What intake manifold are you running currently? If youre running stock, might wanna look into another intake manifold also. But sounds like a nice purchase for ya!!! 'Bout time you start taking advantage of all the potential of that shorblock you got there
