is this the RPM hang thing (that I can fix)?
If the motor has a load on it for any more then 10 seconds when I press in the clutch the cars RPMs will hang at about 1000 rpms. But here is the part I just cant figure out. It will stay there UNTIL the car stops rolling.... as soon as the car literally comes to a stop (like when you feel the weight go back on the read end) the car will drop its idle to its usual 5-600 rpm
Why does this drop ALWAYS happen after the car fully stops? And why will it not do it when the car is moving (without a load on the engine)? Is this some kind of computer thing?
RPM hang happens when you shift gears. Say you shift at 2000 rpms. With your foot off the gas and the clutch in the motor will stay at 2000 rpms a couple of seconds before dropping back. I was told that Ford built the car this way for emissions standards. If it bothers you there is a simple fix. You take your Idle Air Controller (IAC) off. Using your current gasket, you make a new gasket (gasket material from Autozone) that has a smaller center hole. You might search for the mod but I think the hole size that you want is 5/16th of an inch. If you make the hole too small the car won't idle with the air conditioner on.
It can also be adjusted in the tune via various settings, as a group sometimes called the virtual dashpot function...
