Anyone have any idle clips of MHS stage II cams?
Ok, cus i was going to say that the NPI cams have different exhaust side specs than the PI's do. So they might not sound exactly the same. Im liking the stage 3's from MPH if i can get my stock valves ground down or find some SS valves for cheap. And i can do it on a weekend at my buddy's shop and he can install them at advertised specs then and i wont have to worry about PTV clearance with the ground down/new valves...right?
Would i still have to have them degreed or could i install them at advertised specs??? I thought degreeing them would be to minimize the PTV clearance. Or could you even advance them a little bit more with new intake valves or no??? Really a newb with cams.
And yes there are people who didn't degree their cams. To me, that is crazy and I would never think about installing cams without degreeing them. Without degreeing the cams you could be leaving a lot on the table or advancing the cams enough to create PTV issues.
Gotcha, so the timing gears that Nick sells would help get rid of that need of the degreeing of the cams??? Or at least cut down on the time needed to degree. And could you degree them advanced from advertised specs if you have the aftermarket/ground valves and/or notched pistons???
Yes, you can advance the timing but if want to do that, stepping up to a bigger cam might be a better idea, I'm not to certain though so don't quote me on that.
Well i figured if you didnt want to be revving it to the moon, a stage 2 (MHS stage 3 equivalent) would be ideal for peak power being somewhat low and the advancing would make for more midrange and possibly stronger peak wouldnt it???
Wow, youre right!!! So for $150, they will degree your cams for you...but do they just degree them with the cam gears and then when you get them shipped to you, are they ready to install???
